Hey guys,
A long time lurker, first time poster, from Australia.
I am interested in water cooling both my GPU's and my CPU. I will be overclocking them to the best possible levels. It will be my first time water cooling, and I would be grateful for any suggestions and advice.
My components are as follows:
MOBO: Asus P8Z68V PRO (GEN3)
CPU: i5 2500k (currently overclocked to 4.8ghz)
CPU Cooler: Coolermaster hyper 212 Evo (push pull)
GPU: 2 GTX 680's in SLI (Both reference cards- one MSI, one EVGA)
RAM: Gskill Ripjaws 8GB 1600mhz
PSU: Antec High Current Gamer 900W
HDD: WD Caviar Black 1TB
SDD: Samsung 840 Pro 256GB
120mm FANS that I could possibly use: Coolermaster 120mm silent Red LED Fan x2 and a BitFenix Spectre 120mm Red LED
I also have an IHAS324 Optical Drive and a Lamptron FC5 V2 Fan Controller (which I was thinking of using?)
Also, I have already purchased two Heatkiller GTX 680 "Hole Edition" Reference Design Water Block- Nickel/Black.
Currently, my case is a HAF 922, however for water cooling, I am considering purchasing either the NZXT Switch 810 or the Corsair 750D. Are these cases good options or should I consider different ones? Which is the better of the two?
The water cooling components I had in mind to purchase, from PCCG, after doing some research, are as follows:
XSPC RayStorm D5 Photon AX360 Water Cooling Kit
Alphacool NexXxoS Monsta 240mm Rad
XSPC G1/4 Black Chrome 7/16 Compression Fitting (x8)
PrimoChill PrimoFlex Advanced LRT Tubing Red 7/16ID 5/8OD 3m
PrimoChill Liquid Utopia Clear Additive 15ml
Koolance Dual VID Connector Adjustable 2-3 Slot Spacing
XSPC Twin 5mm LED Kit Red
XSPC Twin 3mm LED Kit Red
Bitspower G1/4 Matte Black Low-Profile Stop Fitting
NZXT Sleeved LED Cable 200cm Red
Corsair Air Series SP120 Quiet Edition Case Fan (x4)
I think that the above list covers everything; however, I am not 100% sure and would like to know if I am missing anything.
Also, I would really like to know whether these water cooling components are the right choice and are compatible.
Regarding the fan setup, should I use the 3 XSPC fans that come with the kit and the three that I already have (listed above), OR should I purchase 10 of the Corsair Fans for push/pull setup?
Is push/pull necessary for both Rads?
My budget is around $1,000, including the case.
Any suggestions or advice is greatly appreciated.
In summary, I would like to know whether the watercooling components I listed above are sufficient and all I need or whether I am missing anything.
Thank you in advance.
