Hey I was wondering there have been some people that have utilized 2 computer cases for 1 pc. I did some searching but only found people trying to run 2 setups from 1 case.
I've never really been satisfited with some of the cases that I've bought and don't have the cash to splash out on some of the extreme ones. So what I was thinking was buying 2 cheaper cases (antec 300 price range) and setting them side by side.
Left case = motherboard etc.
Right case = hard disks, psu, dvd drive etc.
Then cut a hole on the right side of the left case and feed the cables into a hole on the left side of the right case. Ideally holes big enough to just get the cables out and some nice rubber surrounding it.
That would mean I could gut out the all the bays from the left computer case and open it up nice. There could be some problems with cables reaching etc. Maybe 2 separate holes and then in the right case have things to raise and lower components so they can reach.
The openness of the left case could be nice for a watercooling setup or ducts to direct airflow appropriately.
Has anyone had any experience with something like this?
Any help would be appreciated.
Thanks!
Thanks!
