- May 26, 2007
hi,
i just tried to install my old ide hard drive on my new pc so i could have 1 HDD with xp and 1 with vista but it wouldnt work?!
my new mobo and HDD is sata2 but i have the connections for ide aswell so i made my ide drive a slave plugged in and switched on, then i went into bios the drive was recognised but in boot up config it wouldnt give me the 2 names of the drives only the master. i could only select 1 of them underneath in the hard drives menu so i went into that and the 2 were there but if i selected 1 the other wouldnt appear in boot up! i therefore selected the new drive and rebooted but when it came to load windows it wouldnt load up and went into the safe mode or start up normal screen! i tried both but it kept bringing me back to the same screen so i went into bios again and selected my sata drive and that loaded up but a little slowly and then it installed my other drive onto it! but this isnt what i wanted but i rebooted anyway but i have no option to boot into my other drive and when i select it in bios it wont load up like last time! any help??
