I just finished up my first OC, that i judge successful at least. I was attempting to OC to 4.00GHz on my i5 2500K. I tried going up to 4.5GHz with little success and decided all i need for now is 4.00GHz (may try to work my way up eventually, but for now i just want to game). Listed below are my system specs, BIOS settings, and CPU-Z screenshots. I tested this OC with Intel Burn Test and Prime95 and these results/temps/voltage readings are listed below (sorry for the lack of screenshots for these tests). I have been running this OC for about a week now with no problems whatsoever. From a practical testing standpoint, have ran Skyrim heavily moded for increased visuals,etc. and on Ultra settings with no problems and at a good performance level (no other games as of yet). My voltage Max has never gone over 1.28V (according to CPUHD and HWINFO64) while playing games and generally using my computer at normal load and my temps are usually around the 30C range. My voltage normally is around the 1.26-1.27V range under normal conditions.
So basically, is this a good OC? What do you think? If the forum could review my settings and give any advice/suggestions i would really appreciate it. Thanks!
BIOS Settings (version F6)
--Advanced Freq Settings
CPU Clock Ratio [33x]
BCLK/DMI/PEG Clock Control [Disabled]
BCLK/DMI/PEG Freq [1000--100.00MHz]
Extreme Memory Profile (X.M.P.) [Profile1]
System Memory Multiplier [Auto]
Memory frew [1600] [1600]
Internal Graphics Clock [1100] [Auto]
--Advanced CPU Core Features
PWM Freq control [auto]
Cpu over current protection [auto]
Internal CPU PLL Overvoltage [auto]
Real-time ratio changes in OS [disabled]
Intel Turbo Boost Tech. [auto]
Turbo ratio (1-core) [37] [40]
Turbo ratio (2-core) [36] [40]
Turbo ratio (3-core) [35] [40]
Turbo ratio (4-core) [34] [40]
Turbo Power Limit (watts) [95] [auto]
Core current limit (amps) [97] [auto]
CPU Cores enables [All]
CPU Enhanced Halt (C1E) [auto]
C3/C6 [auto]
CPU thermal monitor [auto]
CPU EIST Function [auto]
Bi-Directional PROCHOT [auto]
--Advanced Memory Settings
System memory multiplier [auto]
Memory Freq [1600] [1600]
Performance Enhance [turbo]
DRAM Timing Schedule [auto]
Profile DDR Voltage [1.5V]
Profile VTT Voltage [1.05V]
Channel interleaving [auto]
Rank interleaving [auto]
--Channel A/B timing Settings
CAS Latency Time [9][9]
tRCD [9][9]
tRP [9][9]
tRAS [24][24]
tRC[33][auto]
tRRD[5][auto]
tWTR[6] [auto]
tWR[12][auto]
tWTP[24] [auto]
tWL[8] [auto]
tRFC[128] [auto]
tRTP[6] [auto]
tFAW[24] [auto]
Command Rate (CMD) [2][2]
IO latency [1][auto]
Round trip latency [37] [auto]
--Advanced Voltage Settings
Multi-Steps Load-Line[disabled]
CPU Vcore [1.335V] [1.280V]
Dynamic Vcore (DVID) [+0.000V][Auto]
QPI/VTT Voltage [1.050V][Auto]
System Agent Voltage [0.920V][auto]
Graphics core [1.075V] [auto]
Graphics DVID [+0.000V][auto]
CPU PLL [1.800V] [auto]
DRAM Voltage [1.500V] [auto]
DRAM VRef [0.750V] [auto]
DRAM Termination [0.750V] [auto]
Ch-A Data VRef. [0.750V] [auto]
Ch-B Data VRef. [0.750V] [auto]
Ch-A Address VRef. [0.750V] [auto]
Ch-B Address VRef. [0.750V] [auto]
--Miscellaneous Settings
Isochronous Support [enabled]
Virtualization technology[enabled]
OC Testing Results—4.00GHz
-Intel Burn Test (IBT)
-Prime95
• 4.00GHz, 1.250V
o Load-line DISABLED
o BOOST TECH RATIO 1 - 4 [40]
o QPI/VTT VOLTAGE [AUTO]
o TURBO POWER LIMIT [AUTO]
o CORE CURRENT [AUTO]
o EIST ENABLED
o Intel burn test-FAILED
Maximum setting, 20 passes
• 4.00GHz, 1.280V
o IBT-PASSED
Maximum Setting, 20 passes
IBR test CPU Vcore Max-1.284VV
IBT test CPU Temps Max- 57,63,61,59
o Prime-Passed Large FFT’s-6.17hours
Prime test CPU VCore Max-1.32V
Prime test CPU Temps Max-53,58,56,54
o Prime-Passed Blend-10.34 hours
Prime test CPU VCore Max- 1.32V
Prime test CPU Temps Max-53,58,54,53
CPU-Z Screenshots while running my PC under normal load
System Specs:
-EVGA SuperClocked 012-P3-1573-KR GeForce GTX 570 HD w/Display-Port (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
- GIGABYTE GA-Z68XP-UD3P LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
- Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive - OEM
- CORSAIR Professional Series HX650 (CMPSU-650HX) 650W ATX12V v2.2 / EPS12V 2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
- Crucial M4 CT064M4SSD2 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD)
- COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case
-G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL (9-9-9-24-2N; 1.5V)
-COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible
-3 [200mm] fans (side, front, top) & 1 [120mm] rear fan; 2 [120mm] push/pull heatsink fans
-ASUS 24X DVD Burner - Bulk 24X OEM
-Intel i5 2500k 3.3 GHz 6MB Cache CPU
C3/C6 [auto]
tRCD [9][9]
tRP [9][9]
tRAS [24][24]
tRC[33][auto]
tRRD[5][auto]
tWTR[6] [auto]
tWR[12][auto]
tWTP[24] [auto]
tWL[8] [auto]
tRFC[128] [auto]
tRTP[6] [auto]
tFAW[24] [auto]
-Prime95
• 4.00GHz, 1.250V
o EIST ENABLED
• 4.00GHz, 1.280V
o IBT-PASSED
System Specs:
