- Aug 5, 2002
Well I can say this at least with my AIO experience. While I got really high temps originally found my main issue was proper pressure on the cpu itself. The original mounting hardware didn't mount properly. No matter how loose or tight the Thumb screws where still produced really high temps. Now your temps are no where near mine not saying it's a problem but could be another issue. I'd think you should be idling in the upper 20s , maybe low 30s pending the room temp.
Also sounded like you went from Intel to AMD with your setup? If that is the case it's very possible that the block might not be making the best of contact. Again just from my experience it works for some great on their boards but others seem to be a bit and a miss for functioning properly. Behind the CPU socket does it look like it's bulging with the block on?
As for the plate, mine looked similar to that but feeling over it was still smooth like. Used AS5 for my thermal paste.
