Okay, this is my 2nd water cooling build (And yes I still haven't finished the first...), and it immediately leaked. It's okay though as I'm running only the reservoir and it rgb lights... It's ironic considering my first build was a frankenstein (And did not leak) and this was as straight to the point as I could get...
After tightening up the pipes I believe the leaks have stopped. So i have some questions:
1. How long do I wait before running the system?
2. I had to tighten some pipes very tightly. Is this a bad sign? Should I redo some stuff?
3. Some of the pipes have bubbles. Will that go away eventually?
4. Should I run another test?
5. How long should I test?
Here are pics. It's a micro atx case with micro atx threadripper board and a 1920x. It's going to have a garbage gpu as this will be a general server machine.
