Just tested this, changed my command rate from 2t to 1t and my physics score went from 9250 at 2t, to 9500 at 1t not to big of a diffrence, but there was a 2fps increase on the test.
Well, I ran 3dmark 11 again three times @1t and 2t and the results are the exactly same it shows an increase in performance. While running @1600mhz 9-9-9-24 2t I averaged 8944 for three runs and @1600mhz 9-9-9-24 1t the average was 9013 3dmarks. I don't think its a margin of error since I ran it three times at each setting an saw the same results each time. I mean grated its not a huge gain but it pushed me above 9000 3dmarks which has been a goal of mine for the last few weeks. I ran my 2500k @4.9ghz my 560ti's at 920mhz each and the ram at 1t &2t. Stoked!
I've wondered about 1t-2T settings myself. My memory is at 2T and was looking for a simple explanation about the performance difference of 1T and 2T and also stability issues. I have 4 memory modules set as dual channel for a total of 8gb in all memory slots. Looks like I'll leave it at 2T. Thanks for the info. guys.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211409
Those your sticks?
With all 4 populated sometimes 2T is necessary for stability.
Your timings are correct otherwise 9-9-9-24 and if vdimm is set to 1.65v then you can increase the memory multiplier to 1600 effective.
You can then try setting 1T, it either works or it doesnt.
generally anymore 2T is only necessary with 8GB sticks (older 4GB modules might be affected as well) or super cheap RAM that is marketed at higher speed or lower timings/voltages than it was designed to run at.
I have the CPUNB at 2400 already and the CPUNB voltage to 1.25 volts. I have heard/read that the Phenom II IMC doesn't like 1600 memory settings. I've also heard that the C3 stepping might handle 1600 memory better than the C2 stepping. I haven't found anything definite to verify that. The voltage can only be changed 0.02 volts at a time. That's why the 1.66v settings. Anything less than 1.66v-1.64v at 1600 and the board won't boot windows.
Oh nice, I just bumped my vdimm to 1.64, set timing 8-9-8-24 t1, and after a few reboots (finnicky Ridata SSS boot), started windows just fine, running on it now as I post. Personal record for me Have to try a bench.
Tough to type, cut my pinkie on my cpu cooling fan pretty good haha.
