I made a small bit about fans many posts ago. If you look at Martins (all we have now since Skinnee let his die), we can see the OPs rads scale VERY well with the right fans. Bundymania is another resource at Xtreme Systems forums folks forget about. He also posts on many EU German forums.
Those rads CAN control the heat.
No one will fess up to the fans needed. So, to help the OP and to get this thread moving, let me suggest some fans. They do not come with earplugs. OP, you bought it, you decide.
Look at this first. You decode it, your problem.
http://img87.imageshack.us/img87/9652/fantable124.png
Fans that might work.
http://www.frozencpu.com/products/1...n_-_1025_CFM_109R1212H1011.html?tl=g36c15s562
http://www.frozencpu.com/products/8...n_-_190_CFM_FFB1212EHE-F00.html?tl=g36c15s562
Fan like this, probably not needed in PUSH/PULL would work. Maybe so, double the fan cost and 38mm fans are THICK.
OP: You are severly underfannaged and underradded for your heatload.
You have TWO choices. Buy a 120x9 Mora rad and NINE AP Fans and run them at 1850 RPM, still pretty quiet.
Or realize your choice of rads needs MASSIVE fannage since they are 30 FPI and you need LOUD assed fans to dissipate the heat.
You made a bad choice in rads. But not really. You got the right rads, but aren't going to like the scream of the PC in the same room if you want to make them work.
OP, you decide Spend $400 more in a new rad (Mora 120x9 and fans), or $240+ on the proper fans for your rads and heatload.
Done
