I'm looking to make a fan hub, as follows...
* 12v from Molex to 4 (or more) 3-pin fans with some sort of voltage controller.
* Use a 3-pin fan header to control the 'voltage controller' for the above.
Anyone point me in the right direction?
I have a single 3-pin fan header on a particular mobo that will regulate via SpeedFan. The problem is that the header is only rated for 1A, probably not good for 4-6 120mm fans. Its still a good built-in control mechanism, just need to use a better power source.
Thanks for any help or info....
