- Oct 13, 2006
- Canada
Hi all. New to this forum, and fairly new to overclocking. I think I have a good basic understanding, but I am up against a bit of a wall and need help.
I am currently OC'ing my 3700 sandy. I have been able to get a stable 2.6 Ghz (10 x 260)with my ram at 1:1 and my core voltage at 1.52.
I have 2 x 1gb OCZ EB Platinum and a DFI Lanparty UT Ultra-D, powered by a
600W OCZ GamerXtreme PSU. I am running the latest official bios release.
Last night I tried to get a new stable run at 2700, with the following specs
-10X270MHZ ht
-ram set on a 180 divider(also tried 166)
-3 3 8 3 11 timings 1T (tried 2T as well) ( I loosened everything up so as to not worry about my ram, but it will run up to 270 without memtest errors)
-Core Voltage 1.52V all the way up to 1.64V
-I tried both auto htt and manaul 3X htt
-My heat peaks at 52 degrees under full load at 1.62V.
I have my Chipset voltage bumped up 1 notch, to I think 1.3V, and my ht voltage up one notch as well(I think 1.6). I am running my ram at 2.78 volts.
I dont really want to run 24/7 at that voltage, but I was able to get a nice 30 second 1M Pi run, and a 27 minute full Pi run, but only about 40 minutes of Prime, and it fails.
I am out of ideas. I have toyed with the idea of a new bios, but am not really sure why this would make a difference on the CPU OC (fill me in if you know better, cause Im new to this), but other then that, I am not sure what I can try.
My CPU stepping is a KAB2E, and I am sure that I will be able to get more out of this system yet, but I just need some help. Thanks in advance...
__________________
DFI LanpartyUT nF4 Ultra-D (not yet modded)
AMD Athlon 64 3700 SanDiego
2x 1GB OCZ EB Platinum Edition PC-4000
eVGA GeForce 7900GS 256mb PCI-E x16
SoundBlaster Audigy 2 (driver version 5.12.1.512)
2X WD Raptor 36gb - SATA Raid
Samsung Black DVD+/-RW
OCZ GameXStream 600W
Arctic Cooler Pro 64
-10X270MHZ ht
__________________
