- Feb 3, 2012
Hi Guys,
Took the plunge and de-lidded my 3770K as even with my huge loop, 90c at 1.28v and 4.7ghz was stopping me testing any further and I really want some more clocks. Also, my core temps were very uneven which has always niggled me.
Plus - I just wanted to do it for the hell of it, so off we go...
Quick test beforehand using ten runs of IBT on normal yield the following results.
After the work was completed, I performed the same test, and yielded the following results.
An incredible max improvement of 32 Degrees C!
And importantly, the cores are now all within 5c of each other, instead of 12c as they were previous, which I expect is a result of the lapping.
Just to be sure it wasnt a fluke, I put ona quick double run on Max settings. results are almost identical.
Pleased?
Oh yes! Now for some more volts and clocks!
Pictures to follow. just uploading.
- Idle Core 1 = 31c
- Idle Core 2 = 26c
- Idle Core 3 = 29c
- Idle Core 4 = 23c
- Max Core 1 = 76c
- Max Core 2 = 88c
- Max Core 3 = 83c
- Max Core 4 = 79c
- Idle Core 1 = 27c (-4c)
- Idle Core 2 = 24c (-2c)
- Idle Core 3 = 26c (-3c)
- Idle Core 4 = 22c (-1c)
- Max Core 1 = 53c (-23c)
- Max Core 2 = 56c (-32c)
- Max Core 3 = 58c (-25c)
- Max Core 4 = 54c (-25c)
Pleased?
