- Nov 12, 2002
- Rootstown, OH
Where did the overclock go after the change?
+1, I'm curious about that too. I've got a 3770K that's pretty hot but don't want to bother with this if the max OC on water doesn't improve.
Great results on your chip though!
This Liquid pro and liquid ultra, what is what, and does it have to be this when doing this?
Post #4?Could you answer this please? I am planning on doing this, but i have no idea what i would use where? ATM i am just using Arctic Cooling MX-4 paste, i know my IHS is far from flat, which is another thing i want to fix at the same time, im 100% sure on how to do that, but this liquid pro and ultra, and where to put what is a still a question i have, and do i have to use this make or are there other makes out there??
Your right earthdog, i missed that, and never mind on the liquid ultra and pro, i found them in Denmark.
It should... but it depends on the chip. If you are sitting at 1.45v 4.8Ghz, it doesnt matter what the temperature is as you are already hitting the 'red' for voltage. However, if you are sitting at 1.35v and 4.8Ghz and hitting 90C, this is something that will likely help get a couple hundred MHz more. It just depends on the CPU.I can tell you that when I delidded mine I managed to overclock up to 4.8ghz with the H100 when it was previously limited to 4.55ghz...
And with the Custom loop I managed 4.9ghz with a max temp of 86C.
Overclocking will most likely improve
