Ryzen Master
HWMonitor
It'll boot to 3600, but it won't be in 1:1 mode. It'll set FCLK to 1066 or something really slow.
I've tried 1.4 with XMP (3600, 16-19-19-19-39). Happy to try again, I'll have to force FCLK to something 1500 a good starting point?.
lightingman117
You can multiquote responses. At the bottom right of each post is a reply with quote button next to it the (") with the (+) sign will let you select multiple posts. When done just hit reply with quote on the last post.
The Infinity Fabric should not need to depart from 1:1 at 3600 mhz.
That's a step in the right direction. I'm pretty sure the system can change the fclk dynamically when all is on auto. try running CB20 and watch to see what speeds it hits. Don't forget that SW isn't always the most accurate
If you keep the CPU clock at auto then FCLK clock will be changing dynamically as Johan already said. Simply, the software will show you various values that not always are correct. Still, the FCLK can't be higher than the memory clock..
All higher ASRock X570 mobos use the same design or even share the same PCB. Taichi, Creator, Extreme, Steel, etc., all work about the same and OC CPU and memory the same. All use almost the same BIOS (with little changes) and all run with memory at 3600 and IF 1800 at auto. Only higher clocks require to set manual IF ratio.
Not every CPU runs at 3600/1800 IF 1:1 but most should run like that. Not every CPU will even boot at anything higher. Usually, higher memory capacity is causing problems with a higher mem clock and FCLK 1800+. My 3900X runs the same on ASUS and ASRock motherboards so up to 3800/1900 with a 2x8GB kit, up to 3733/1866 with a 2x16GB kit and up to 3600/1800 with a 2x32GB kit.
Typically, up to 3800, you shouldn't even change SOC voltage and most other things as long as the motherboard is not undervolting. It's like all at auto and play with ratios.
Your memory is based on Hynix IC so you can count on something like 3600-3800 16-19-19 or 16-20-20 and 1.35-1.45V. There can be also good results at 4133-4266 18-24-24 1.35-1.45V as long as the IC can handle it ... but I don't know how good IC is G.Skill using in these kits. If XMP is causing some weird behavior then you can try manual settings as I said and disable XMP. The motherboard should adjust all other timings which you can tweak manually later (first be sure that all is fully stable).
First, I really appreciate the help thus far and am very thankful. I am only seeking to understand what is going on.
This can't possibly be true. If it was then my 3600/auto R20 score of 6900 would equal the 3600/1800 R20 score of 7100.
I have poured over the scarce Zen2 IF documentation that I could find and I find no mention of the IF speed changing dynamically. If it was it would also incur a ram speed change with it. I have never heard nor read of DDR4 speeds changing nor can I find any documentation on that.
If this is indeed true, can someone point me to the documentation to how it's implemented?
I also don't get this. The proof to me is in the numbers. Software or Soft-Hardware [BIOS] has to report something we can reasonably trust. What other program or way would one determine IF (FCLK) speed and RAM speed to determine if in-fact the ASRock x570 Taichi is running IF at 1800 in auto mode? I find no mention of it in BIOS; RM (when it was installed) reports same as HWinfo. If we truly can't trust what is being reported, then benchmarks should show us that if 'auto' FCLK is working as expected then the results should be reasonably close (within Std Dev).
Absolutely, this all makes perfect sense. I was thinking if/when I go to 64GB I'll loose some UCLK speed and be forced down in FCLK.
Buildzoid's chart on this is excellent. https://docs.google.com/spreadsheets/d/12poUIs4mYn6sd8Em78cKPk73lnux2rDiJHKCCD9g2QQ/edit#gid=0
