I was just speaking from my own experience and what I had to do to get things back to normal. It may not "change" values but it is working low level on the motherboard. It also could have been the Windows crash that messed up RM a bit
If I were buying them I would go for something like this, Samsung B-Die typically is the easiest to work with. https://www.newegg.com/g-skill-32gb...820232903?Item=N82E16820232903&quicklink=true
I've been working with and reviewing Zen since it launched. I'm also a bencher. I have tried a few different kits and I always come back to Samsung since it just seems to work. I can put two different sets in a system and it'll boot up just fine. I realize there's a bit of a premium but to me, it's worth it. Any other kit I have had I have sold and the only thing left in the stable is Samsung B-die.
I have to ask about the RAM training that you keep bringing up. Is this just a long boot time or is it reverting to 21333 and you need to reboot?
Maybe these 16GB NEO sticks??... Although there shouldn't be much difference between these and the B-die Royals.
https://www.newegg.com/g-skill-32gb-288-pin-ddr4-sdram/p/N82E16820232860?Item=N82E16820232860
https://www.newegg.com/g-skill-64gb-288-pin-ddr4-sdram/p/N82E16820232864?Item=N82E16820232864
Sometimes long boot, sometimes no post and reset to boot, sometimes revert to 2133. It's inconsistent. It's also weird that I can run memory stress tests (p95) and it is stable, but posting/booting is always difficult.
I looked at NEO vs Royal same timings and can't find a consensus. 20$ is worth it to me if they're binning Royal better so I never have to deal with this again.
I don't see any point to what you're going through with the RAM. Just run it at the 3600/1800 MCLK/FCLK XMP setting. I have cheap G.Skill/Hynix DDR4-3600 running at 16-19-19-19 with no issues with my 3900X/MSI B450M combo. There's very little if anything to be gained pushing the infinity fabric a bit higher in real world apps. Playing with secondary timings is also largely a waste of time.
Are there options in that BIOS to set the boot voltage for the RAM? I know they have it on CHVIII it really helps.
Like Dave said pushing that much for little gain isn't worth the headache and spending more $$$ on RAM. If it'll work consistently at 3600/1800 why not just go with that
