Whenever I start up google earth, my comp freezes. This also happens whenever I start google sketchup, which is odd, because last week it worked fine. I installed direct x from google earth's site, and have the most recent driver for my video card, so I'm all out of ideas. When I try test direct3d on the display page of dxdiag, the comp freezes again. Any input would be greatly appreciated.
Heres my dxdiag:
System Information
Time of this report: 4/29/2008, 12:08:20
Machine name: RUDDY
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
Language: English (Regional Setting: English)
System Manufacturer: Equus Computer Systems
System Model: Nobilis
BIOS: BIOS Date: 06/28/04 13:38:58 Ver: 08.00.09
Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz (2 CPUs)
Memory: 2046MB RAM
Page File: 322MB used, 3104MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Matrox Parhelia 256MB
Manufacturer: Matrox Graphics Inc.
Chip type: Matrox Parhelia
DAC type: Integrated, 400 MHz
Device Key: Enum\PCI\VEN_102B&DEV_0528&SUBSYS_1030102B&REV_06
Display Memory: 256.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Default Monitor
Monitor Max Res:
Driver Name: MTXPARHD.dll
Driver Version: 6.14.0001.2327 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 3/28/2007 13:04:14, 1675648 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: MTXPARHM.sys
Mini VDD Date: 3/28/2007 13:05:16, 536192 bytes
Device Identifier: {D7B71ECB-4668-11CF-8C7A-3130A7C2CB35}
Vendor ID: 0x102B
Device ID: 0x0528
SubSys ID: 0x1030102B
Revision ID: 0x0006
Revision ID: 0x0006
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Creative Sound Blaster PCI
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1274&DEV_5880&SUBSYS_80011274&REV_04
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: es1371mp.sys
Driver Version: 5.01.3612.0000 (English)
WHQL Logo'd: n/a
Date and Size: 6/3/2002 12:18:32, 40832 bytes
Other Files:
Driver Provider: Creative Technology Ltd.
HW Accel Level: Full
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x0
Format Flags: 0x0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Creative Sound Blaster PCI, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Creative Sound Blaster MPU-401 [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
Creative Sound Blaster MPU-401 [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0A81, 0x0101
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x24D4
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 23:08:44, 57600 bytes
| Driver: usbd.sys, 8/4/2004 02:00:00, 4736 bytes
Gameport Devices
+ Creative AudioPCI (ES1371,ES1373) (WDM)
| Matching Device ID: pci\ven_1274&dev_5880&subsys_80011274
| Service: es1371
| Driver: ksuser.dll, 8/4/2004 01:56:44, 4096 bytes
| Driver: ksproxy.ax, 8/4/2004 01:56:58, 130048 bytes
| Driver: ks.sys, 8/4/2004 00:15:22, 140928 bytes
| Driver: drmk.sys, 8/4/2004 00:08:00, 60288 bytes
| Driver: portcls.sys, 8/4/2004 00:15:50, 145792 bytes
| Driver: stream.sys, 8/4/2004 00:08:04, 48640 bytes
| Driver: wdmaud.drv, 8/4/2004 02:00:00, 23552 bytes
| Driver: es1371mp.sys, 6/3/2002 12:18:32, 40832 bytes
+-+ Game Port for Creative
| | Matching Device ID: *ctl7001
| | Service: gameenum
| | Driver: gameenum.sys, 8/3/2004 18:08:22, 10624 bytes
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/3/2004 23:58:36, 14848 bytes
| Driver: kbdclass.sys, 8/4/2004 02:00:00, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes
+ Microsoft USB Wheel Mouse Optical
| Vendor/Product ID: 0x045E, 0x0040
| Matching Device ID: hid\vid_045e&pid_0040
| Service: mouhid
| Driver: mouclass.sys, 8/4/2004 02:00:00, 23040 bytes
| Driver: mouhid.sys, 8/17/2001 13:48:00, 12160 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: Standard Modem
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM3
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 0.8 GB
Total Space: 20.0 GB
File System: NTFS
Model: ST380013AS
Drive: D:
Free Space: 33.8 GB
Total Space: 56.3 GB
File System: NTFS
Model: ST380013AS
Drive: E:
Model: LITE-ON CD-ROM LTN-529S
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/4/2004 02:00:00, 49536 bytes
System Devices
Name: Intel(R) 82875P/E7210 Processor to PCI to CSA bridge - 257B
Device ID: PCI\VEN_8086&DEV_257B&SUBSYS_00000000&REV_02\3&267A616A&0&18
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 23:07:48, 68224 bytes
Name: Intel(R) 82875P Processor to AGP Controller - 2579
Device ID: PCI\VEN_8086&DEV_2579&SUBSYS_00000000&REV_02\3&267A616A&0&08
Driver: C:\WINDOWS\system32\DRIVERS\AGP440.SYS, 5.01.2600.2180 (English), 8/3/2004 23:07:42, 42368 bytes
Name: Intel(R) 82875P/E7210 Memory Controller Hub - 2578
Device ID: PCI\VEN_8086&DEV_2578&SUBSYS_00000000&REV_02\3&267A616A&0&00
Driver: n/a
Name: Intel(R) 82801EB USB Universal Host Controller - 24DE
Device ID: PCI\VEN_8086&DEV_24DE&SUBSYS_425A8086&REV_02\3&267A616A&0&EB
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 20480 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 57600 bytes
Name: Intel(R) 82801EB USB2 Enhanced Host Controller - 24DD
Device ID: PCI\VEN_8086&DEV_24DD&SUBSYS_425A8086&REV_02\3&267A616A&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 26624 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 02:00:00, 7168 bytes
Name: Intel(R) 82801EB Ultra ATA Storage Controllers
Device ID: PCI\VEN_8086&DEV_24DB&SUBSYS_425A8086&REV_02\3&267A616A&0&F9
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 13:51:52, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:44, 95360 bytes
Name: Intel(R) 82801EB USB Universal Host Controller - 24D7
Device ID: PCI\VEN_8086&DEV_24D7&SUBSYS_425A8086&REV_02\3&267A616A&0&EA
Name: Intel(R) 82801EB USB Universal Host Controller - 24D4
Device ID: PCI\VEN_8086&DEV_24D4&SUBSYS_425A8086&REV_02\3&267A616A&0&E9
Name: Intel(R) 82801EB SMBus Controller - 24D3
Device ID: PCI\VEN_8086&DEV_24D3&SUBSYS_425A8086&REV_02\3&267A616A&0&FB
Driver: n/a
Name: Intel(R) 82801EB USB Universal Host Controller - 24D2
Device ID: PCI\VEN_8086&DEV_24D2&SUBSYS_425A8086&REV_02\3&267A616A&0&E8
Device ID: PCI\VEN_8086&DEV_24D1&SUBSYS_425A8086&REV_02\3&267A616A&0&FA
Name: Intel(R) 82801EB LPC Interface Controller - 24D0
Device ID: PCI\VEN_8086&DEV_24D0&SUBSYS_00000000&REV_02\3&267A616A&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/17/2001 13:58:02, 35840 bytes
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_C2\3&267A616A&0&F0
Name: Intel(R) PRO/1000 CT Network Connection
Device ID: PCI\VEN_8086&DEV_1019&SUBSYS_30258086&REV_00\4&3B3CB9B1&0&0818
Driver: C:\WINDOWS\system32\DRIVERS\e1000325.sys, 7.00.0036.0000 (English), 3/11/2003 00:21:36, 121344 bytes
Driver: C:\WINDOWS\system32\Prounstl.exe, 7.00.0005.0000 (English), 3/3/2003 10:26:52, 118784 bytes
Driver: C:\WINDOWS\system32\e1000325.din, 9/2/2002 20:34:38, 2725 bytes
Driver: C:\WINDOWS\system32\IntelNic.dll, 2.04.0000.0000 (English), 12/28/2002 23:00:00, 24064 bytes
Driver: C:\WINDOWS\system32\e1000msg.dll, 2/11/2003 03:58:48, 126976 bytes
Name: Creative AudioPCI (ES1371,ES1373) (WDM)
Device ID: PCI\VEN_1274&DEV_5880&SUBSYS_80011274&REV_04\4&2E98101C&0&18F0
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/4/2004 01:56:44, 4096 bytes
Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/4/2004 01:56:58, 130048 bytes
Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/4/2004 00:15:22, 140928 bytes
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/4/2004 00:08:00, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/4/2004 00:15:50, 145792 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 8/4/2004 00:08:04, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 02:00:00, 23552 bytes
Driver: C:\WINDOWS\system32\drivers\es1371mp.sys, 5.01.3612.0000 (English), 6/3/2002 12:18:32, 40832 bytes
Name: Matrox Parhelia 256MB
Device ID: PCI\VEN_102B&DEV_0528&SUBSYS_1030102B&REV_06\4&1A99067F&0&0008
Driver: n/a
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/4/2004 02:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/4/2004 02:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/4/2004 02:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 02:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/4/2004 02:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/4/2004 02:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/4/2004 02:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/4/2004 02:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/4/2004 02:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/4/2004 02:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 02:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/4/2004 02:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/3/2004 18:08:22 10624 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 82432 bytes
system.dll: 1.00.3705.6018 English Final Retail 4/13/2008 12:55:44 1179648 bytes
system.dll: 1.01.4322.2407 English Final Retail 7/11/2007 11:52:55 1232896 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 8/22/2007 11:14:24 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 4/29/2008 11:32:49 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 4/29/2008 11:32:50 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 4/29/2008 11:32:50 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 4/29/2008 11:32:51 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 4/29/2008 11:32:51 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 4/29/2008 11:32:52 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 4/29/2008 11:32:52 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 4/29/2008 11:32:53 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 4/29/2008 11:32:53 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 8/22/2007 11:14:24 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 8/22/2007 11:14:25 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 8/22/2007 11:14:25 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 8/22/2007 11:14:26 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 8/22/2007 11:14:27 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 8/22/2007 11:14:23 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 8/22/2007 11:14:24 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 8/22/2007 11:14:23 223232 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/4/2004 02:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 02:00:00 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 02:00:00 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:00:00 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:00:00 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 8/22/2006 04:05:26 498742 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:00:00 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 02:00:00 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:00:00 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 20480 bytes
qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 21:47:18 211456 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:00:00 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:00:00 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:00:00 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:00:00 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:00:00 733696 bytes
quartz.dll: 6.05.2600.3243 English Final Retail 10/29/2007 17:43:03 1287680 bytes
strmdll.dll: 4.01.0000.3936 English Final Retail 8/21/2006 09:52:08 246814 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 02:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 02:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 02:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 02:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 02:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 02:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 02:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 02:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:00:00 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 01:56:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 17:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 17:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 17:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 02:00:00 118272 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:00:00 1428480 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 17408 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:00:00 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.3243
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,1.00.0003.0079
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.3243
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.3243
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.3243
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3243
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.3243
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.3243
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.3243
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.3243
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,2.00.0001.0001
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.3243
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.3243
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.3243
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.3243
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.3243
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Decoder,0x00600000,2,3,NeVideo.ax,2.00.0000.0008
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.1442
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3243
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.3243
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.3243
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.3243
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
Nero File Source,0x00200000,0,1,NeFileSrc.ax,1.00.0000.0006
Nero DVD Decoder,0x00600000,2,3,NeVideo.ax,2.00.0000.0008
NeroDigital Parser,0x00600000,0,3,NDParser.ax,2.00.0001.0001
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.3243
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.3243
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.3243
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3243
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.3243
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.3243
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.3243
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.3243
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.3243
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.3243
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.3243
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.3243
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.3243
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.3243
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.3243
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.3243
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.3243
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.3243
Audio Capture Sources:
Creative Sound Blaster PCI,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Creative Sound Blaster MPU-401,0x00200000,1,0,quartz.dll,6.05.2600.3243
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.3243
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.3243
WDM Streaming Capture Devices:
Creative Sound Blaster MPU-401,0x00200000,2,2,,5.03.2600.2180
Creative Sound Blaster PCI,0x00200000,2,2,,5.03.2600.2180
WDM Streaming Rendering Devices:
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
Creative Sound Blaster PCI,0x00200000,1,0,quartz.dll,6.05.2600.3243
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.3243
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.3243
DirectSound: Creative Sound Blaster PCI,0x00200000,1,0,quartz.dll,6.05.2600.3243
WDM Streaming System Devices:
Creative Sound Blaster PCI,0x00200000,10,2,,5.03.2600.2180
Heres my dxdiag:
System Information
Machine name: RUDDY
Memory: 2046MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
Monitor Max Res:
WHQL Logo'd: n/a
VDD: n/a
Vendor ID: 0x102B
Device ID: 0x0528
Revision ID: 0x0006
Revision ID: 0x0006
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: n/a
Other Files:
Cap Flags: 0x0
HW Memory: 0
Registry: OK
Cap Flags: 0x0
Format Flags: 0x0
DirectMusic
Acceleration: n/a
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Registry: OK
USB Devices
+ USB Root Hub
| Service: usbhub
Gameport Devices
| Service: es1371
| | Service: gameenum
PS/2 Devices
| Service: kbdhid
| Service: TermDD
| Service: mouhid
| Service: TermDD
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
Drive: C:
Free Space: 0.8 GB
File System: NTFS
Model: ST380013AS
Drive: D:
Free Space: 33.8 GB
File System: NTFS
Model: ST380013AS
Drive: E:
System Devices
Driver: n/a
Driver: n/a
Driver: n/a
DirectX Components
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
Midi Renderers:
BDA CP/CA Filters:
Audio Renderers:
