Hi, I have a PSU with two 12V rails rated at 17 amps, includes one six pin pci-e plug and two chains of three 4-pin molex plugs each. I will be installing a video card that uses two 6-pins and thus I will use the included 6 pin plug as well as an adapter using two of the 6 molexes (one is used by my DVD drive but I have a SATA Blu-ray that will use a SATA power cable instead later (I have two or three of those too). Is it better to use two 4 pin molexes from the same chain or one from each? Thanks in advance.
