4 yearly update time....
Jolyonekenobi
Hi guys
Been looking at various forums to try and get some help but this one seemed to have the most friendly approach to helping people out!
I live in the UK and am not a "HARDCORE" PC enthusiast but I do like to get the best I can out of my money. As such I do spend time on each build. I would really value some input from you chaps. I deliberately spent a long time on this initial post so that you get all the info you need straight off - hence it is very long :-/
I've had my current system for ~4 years now and the only thing I upgraded was my GPU (see below.) Here are my current system specs:
Asus P5QL Pro
Intel E7300 Running at 3.5Ghz - Arctic HS - can't remember the model now!
Antec Earthwatts 650w
2x2Gb OCZ Platinum
Sapphire 4870 1Gb - This I upgraded about a year ago to a Radeon HD 6850 (I was poor and it was on offer :) )
1x Seagate 500Gb generic HD
Whole thing housed in an Antec Plusview 1000 AMG (best pic I could find)
My primary occupations are gaming and listening to music. Simple stuff :)
Case - I have fallen in love with Fractal Designs cases - specifically the R4 Titanium
I'm not going to link the following - no need:
Intel 2500K
G.Skill Ripjaws 2x4Gb
Here I get to the part where I need your help (bear in mind I am looking to get (an easily achievable) 4.5Ghz 24/7 OC, air cooled.)
I am looking for a Z77 mobo - this is what I had in mind Asus P8Z77-V LX - this is roughly my price point but I would welcome alternatives. I really liked the look of the BIOSTAR TZ77XE4 but I can't buy it from my preferred supplier :screwy:
Is there any advantage to buying 1600/1866/2000Mhz memory given my needs?
Will my PSU continue to suffice - I am aware it is getting on a bit and will be looking to replace it in about a year or so.
I really need some help with CPU cooling - noise is an issue for me so quieter the better. I have read so many reviews that my head is starting to hurt.
So - tl;dr
Heatsink help - quiet is important but it has to keep my baby cool!
Need help with memory speeds - also welcome general advice around manufacturers
Z77 motherboard assistance (£80-£100 / $125 - $155)
PSU size enough for now?
Any other suggestions!
I'm sorry this is a massively long post but I tried to avoid the whole "what do you want it to do" - "what do you want to spend" rigmarole.
Thanks in advance if you managed to read it and can help me out!
Current PSU is fine.
So you're just looking at a motherboard/RAM/CPU/case? What about getting a SSD?
6850 is more of a low-mid range gaming card, but no need to change it if it's meeting your needs.
Do you have a nice speaker setup, ever considered a discrete audio card? (Basically a nice DAC on cheap, and an amp too if you're using headphones)
Ah - you've hit on the bits that are at the tail of my upgrade!
I have been thinking that a 128Gb SSD would be worth investing in as a boot drive (plus a home for Eve online which I play quite a bit.)
As for a DAC and an amp - any suggestions on the cheap?
I know the 6850 is hardly a behemoth of a card but it's sat in such an old system I need to upgrade the core system first! Any thoughts on the HS / memory / mobo options?
