http://www.newegg.com/Product/Produ...&AID=10446076&PID=3754110&SID=skim1132X509988
^ This one takes 3, at 16x/16x/4x.
Gskill should be fine...
ight i think the best way for both of us would be just to 16/16 just run two cards and im not sure if the gskill rip jaw ram will fit in the mother boards i posted how would i find out.
what?
lol i took a guess there thinking that i could run 16x/16x if just ran 2 cards and i wanted to know if the g skill rip jaws which are ram would fit the mother boards posted earlier also which would be a better case haf 922 or antec 900 two
only LGA1366 motherboard will give you true 16/16 setup for sli. im not sure why the rip jaws wouldnt fit? i have a 2x2kit in my GB-P55M-UD4 with no problems...
nothing wrong with that ram but you should have gotten lower cas timings. for a small jump in cost this would have been the better way to go IMOi chose this why is this bad is it not going to work cause i already paid for it.
http://www.newegg.com/Product/Produ...1277&cm_re=gskill_ddr3-_-20-231-277-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303
or these
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231321
