- Jan 10, 2012
- Thread Starter
- #61
4.5ghz gives me a peak of 62c core temp.
what ever it is delivered with, i will look at those numbers tonight, starting monday it's teardown and rebuild for that machine. it's a bit amazing to me how in two months in this case the number and size of the dust bunnys that build up, massive airflow i assume.
This reading is taken from the sensor fixed in CPU socket on Motherboard.
As designed and fabricated, AMD CPU's have a series of temperature diodes (how many they won't say as it's "proprietary")
Gosh darnit!
With that type of 'tude, it wouldn't be surprising if AMD also refuses to help the FOSS communities for their GPUs and thus always require proprietary drivers!
More likely to boycott AMD for making basic thermal sensor info that Intel don't, a trade secret!
tore down, cleaned system, replaced old pump/res with an xspc x20-750.
found tim dried to sand remounted block, reset rtc/cmos. reran prime95 for 20 mins and it has improved alot!!!!
my system is still freezing at 4.6 and up, I think it the operating system because when i reboot it will post and bring up the black os choice sceen.
sounds like memory corruption, i'm not sure i can help you with that, memory is not my strong suit.
The min value is 13°C (55°F) and the current value is 15°C (59°F). How cold is the room you are in? This is just water cooling with fans, right?
TCore will always show low readings because of the way the algorithm that's used to derive them works. Below a certain temp it gets thrown off and will show a rediculously low temperature. Again....TCore is unimportant. TCase (CPU Temp) is the one that is a "real" reading (TCore is mathmatically derived from TCase) and is the one that is relevant to the listed maximum temperature (TCase Max).
