- Aug 30, 2012
When oc'ing my 8150 and changing the CPU Voltage to, say, 1.36v @ 4.3GHZ do I need bother to change the Vcore setting in HW Power Management? There are options for; 3.3V, 5V, 12V and Ignore.
Also, is there a way to Completely disable the IGP? I use an XFX 9650, OC'd to 900mhz core and 1325 Memory but that IGP is cooking and not even being used! I've set the IGP speed from 700mhz to 200mhz (the lowest possible), turned UMA off, disabled IGP Boost technology and it's still being used! older mainboards use to have an option to disable them if I recall, typically under the "Onboard devices" section.
