8350 with formula 7 antec heat paste OC result so far
shawnmcc
As before I said I got a 8350 with antec heat paste here are the results of overclock so far.
Under load at 4.4 ghz 1.42 volt turbo still enabled
no load but later I discovered it turbos up to 4.5ghz
I still have room to push it further even under load with prime 95
What are you cooling the processor with? As far as the TIM goes, from the very best to the worst you're only going to see around a 4-5c difference in temps. The mount of the heatsink on the Cpu is more important then the actually TIM used, in most cases.
