Newb to overclocking here, so I've been using AMD CPU OverDrive as it seems straightforward. I ran the CPU stability test they provided and it lasted til 4.1-4.2 Ghz before my system rebooted itself. First thing I noticed was that it was running the test at 1.5v all the way from 3.3 Ghz. If I try overclocking from 3.2 all the way to 3.3-4.0, always the voltage changes from 1.4 to 1.5. After researching/googling this overclocking for days, I've come to learn this is quite high and apparently near the cards max. Is this safe? Is there a way around this and if so, what do you recommend given my PC's specs or what's best for my situation?
Thanks!!
PC Specs -
Motherboard: ASUS M4N75TD AM3 NVIDIA nForce 750a SLI ATX AMD Motherboard
CPU: AMD Phenom II X4 955 BE Deneb Quad-Core 3.20 GHz Socket AM3 125W (RB-C3 Revision)
GPU: SAPPHIRE Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP
PSU: EVGA SuperNOVA 750 G2
Cooling: Cooler Master Hyper 212 Plus CPU Cooler
Thanks!!
PC Specs -
