- Jul 14, 2013
- Holed up in Branford, CT
I am hardly an overclocking expert and am learning a lot here. I would like any input and advice on these screenshots.
Looks okay from here and if you like it is even better.
RGone...
Better cooling, more vcore will get you a better overclock. It's pretty much that simple.
Couldn't get that 6th core going eh.
4 cores will increase the OC and lessen the heat.
I couldn't boot with the sixth core no matter what I did.
That's pretty normal. Mine wouldn't post the 4th core. Had to use 0,1,2,3 and 5th cores, otherwise it would just hang at the splash screen.
Aye. I can give you warp speed, but she'll not take it for long without better cooling for the Dylithium crystals.
What kind of cooler do you have on that thing anyway? I have mine sitting at 3.84 but I run 1.43v on it which equates to 1.5v when LLC kicks in, I could run it higher but trying to keep that cpu socket temp below 60.
