- Apr 30, 2010
- Earth, usually.
I have the older asus evo board and wanted to use it. have another one with a 965BE which has been running for 2yrs overclocked to 3.8g at bios 901 i think. it has been totally trouble free and been all over the place as i tested out stable settings. it had been used to oc and open a 4th core on my original (for that particular board) 3core 720BE. it immediately opened up the 4th core and bingo. i got rid of that cpu and moved right into the 965.
I just put the 960T BE 4core in it and am unable to do anything . i updated the bios to 2003 from901 or 604, where ever i had left it off in 2010.
it fails everything. i have used at least 3 other processors in this asus board, it is a well known overclocker for this 960t cpu , yet i can get it to do only 'auto' or it black screens. i can get it to boot only if i disable unleashing but no unlocked core and the error message that 'overclocking failed' and the F1 option to reset bios. i have done all changes in bios as i had before . i tweaked voltages for cpu and ht move the fsb times around, did not take the ddr3 1600 down to 1333 as some had, but others have been ok with leaving it at 1600. the ram is the same i used on this board with the other build and tested out fine in mem test.
i have another 965 4core and a 1090T be 6 core in gigabyte boards which have overclocked easily and well.
i am less interested in bumping out 2 'free' cores than just overclocking the base and/or turbo multipliers and fsb combo as i have in other builds. i have tweaked the voltages, within standard increments as i re try the bios settings. I entered this build in the 'details' part of the cp or whatever it is. but it doesnt seem to be showing up in the builds. beyond the 2 things listed in the title, i have 8gig gskill ddr3 1600 cl9 approved list, raidmax low end 530w atx rx530ss meets crossfire specs, though i would use it for that and the gpu is gigabyte HD4670 zalman fan version 1gig ddr3, hdd is Samsung spinpoint f3 1T..
i must be overlooking something yet do not know what, i go one at a time with lots of restarts. but when i get to the acc/unleashing it black screens. i do not know if enabling the surge protection is interfering with the other voltage changes.
the mb and cpu temps, core temps have been well within the lower range but the llc seems to be bumping the voltage up to 1.46 or more on the vcore temp for no particular reason. i have disabled the C&Q and C1 but leave the turbo ratio and mult. alone, have to really, so far
i didnt really know where to post this, in the motherboard or cpu, but since i already know this board from over 2yrs tweaking the other , twin, of this, i guess the unknown quantity is the cpu and its mysteries.
there is one more bios update but it seems to be solely for newer gpu compatibility and this one,2003 directed at the thuban or 6cores segment of the phenom II with turbo enhancement i have not used the turbo v or key, nor aod for software tries, i have a pretty good idea where i would like to go with this thing only getting there is a rocky path, so far. i must be leaving something enabled or disabled and not seeing it or overlooking it? i hope. it is responding(the cpu) almost as if it isnt a BE though the box and numbers indicate it is. and,it is always easier to blame the product for operator failures.
thanks for any insights or experiences
JD
JD
