XeonStrikeForce said:well we don't want the recovery compressor to flood with oil from the unit we are taking the refrigerant from! so the intake sep is a fail safe.
XeonStrikeForce said:looking very good. awsome job mate.
greenmaji said:Did you build a quad-becket skimmer?
Nice work as usuall
greenmaji said:Mixing those gasses, Xenon has a thread not to long ago that he was talking about that.
greenmaji said:And I'm thinking you are not going to get the Iwaki's heat out of the loop unless its air cooled, then vented away from the loop. That idea takes all the motors heat and puts it directly into the loop (and do you know the operating temeratures?)
XeonStrikeForce said:*Hits head on wall* you HAVE to mix Gases to get the right capacity out of the compressor!, if you don't you can use Propan as it is the next closest.
But to make an azeotropic replacment you need a 55/45% Mix of R-134a & R-290 by weight.
MarkS said:First, most of the A/C units I've seen use R22. I was planning on using R134a, just because I can buy it legally. Will a compressor rated for R22 function with R134a? I know that there are car A/C conversion kits that change a R22 system to R134a, but will this work in this case?
Second...
I was thinking about how to cool the Iwaki pump I will be using for this system. I thought about wrapping a 3/8" copper tube around the motor and connect this either in series or parallel to the evaporator. Iwaki's run real hot and they have a very noisy fan. I wanted to remove the fan and bring the pump temp down to the point where it will not influence the coolant temp. Will this work?
Pf.Farnsworth said:...not sure what you mean, pumps dont have "fans". Do you mean an "impeller" ? And they are not that noisy, it depends on the model and impeller housing. The japanese made once are quieter.
