Got what I believe to be a t-bred a. The code is AXDA 2000 dut3c.
From 1.66 i've clocked to up to 1.937 @ 1.65 volts. Thats only a .05 volt increase. I have an older abit kt7a v1.3 with sdram running @ 155 fsb case 2. I can't push the ram any faster but another 5 fsb would take me to 2000 exactly.
Just wanted to encourage those with older mboards
With my 8500 i get 7500 3dmark 2001se points. Not bad!
I do however have a problem with adjusting multipliers. if i change it at all the system wont post. It's wierd cause it used to work fine untill one day it decided not to. Not sure if its bios update related (cant remember) but very annoying indeed. I think it happened after i cleaned the pc parts (dust removal) Any thoughts?
cheers to another successfull overclock!
