- Dec 27, 2008
There are two main methods of using the upgrade version of Vista and Win 7 to do a clean install.
1. Do an initial "custom" install of the OS (don't enter the product key and don't try to activate; don't bother with updates) immediately followed by a repeat "upgrade" install begun from within Windows by removing and reinserting the install disc after booting into Windows following the initial custom install. Essentially, this uses the first install as the basis for the upgrade.
2. Doing a "custom" install and then doing a simple registry hack so you can activate the product.
#2 Works quite well and takes less time but I discovered two problems with it. The first problem is that if your master boot record (mbr) gets corrupted you won't be able to fix it with the upgrade install disc. You will get an error message telling you that you are using the wrong version of Windows to do the repair.
The second problem is that it will not allow you to do a dual boot setup with a Linux distro. The Linux (I used Ubuntu) installer cannot see the existing Windows OS for some reason.
Conclusion: Though the method #1 of doing a clean install of Windows with an upgrade version is more time consuming, it won't bite you in the butt down the road.
