HumbleWanderer
- Jan 17, 2015
Hi guys, well as the title suggests I need some help concerning water cooling:
First off I'm planning to water cool my pc, because I wish to overclock both my CPU and my GPU, and I have a few questions.
First off, what's the difference between a cooling set up as shown in here: http://www.overclockers.com/beginners-guide-water-cooling/ , and something like Corsair's H100i, or a CoolerMaster Seidon 240M. Which is better? Which is cheaper? Which is easier?
Secondly, if I were to go for a water cooler like Corsair's, which one would you recommend? A few I've looked at are the Seidon 240M, the H100i, the Swiftech H240X, and the Noctua NH-D14.
Thirdly: If anyone has anything else to add about water cooling and overclocking in general I'd love some advice here, any at all would be great
Lastly, my specs:
Case: http://www.overclockers.co.uk/showproduct.php?prodid=CA-039-IW&groupid=2362&catid=2277&subcat=0
Motherboard: AsRock Killer Z87
CPU: Intel Core i7 4770K
GPU: Nvidia GeForce GTX 770
Thanks in advance for any help guys
Lastly, my specs:
