Welcome to the forums
I'm looking to build a pc based around the A8-3870k. I know the GPU benefits from faster RAM, and if I did my research correctly, the A8 APUs only support up to 1866mhz RAM. =
That appears to be correct.
I'm trying to find a motherboard with guaranteed support for this RAM. =
Not sure what guaranteed support is to be interpreted to mean.
The details page on almost all of them say they support it (on Newegg) but reading through the reviews, I see that a lot of people either only use 1600mhz RAM =
There is nothing that forces them to use DDR1866 ram.
or their 1866mhz ram isn't recognized as 1866mhz. =
That is entirely possible. The reason can be due to SPD programmed into the memory itself or how the motherboard interprets the SPD. Neither of which means the ram speed cannot be manually adjusted to DDR1866 speed. I have not read any of the reviews you refer to at the Egg, since I do not intend to run an APU system at this time. However whenever I have done any reading of Egg reviews, I always have to remember that the reviews can be written by users of any skill level and reading the review must be done very closely to try and determine if that reviewer had skills enough to justify putting much stock in what his review specifies as pros and cons.
Anyone know of a board that will 100% support 1866mhz RAM? =
Since a search in g00gle finds most desktop A75, FM1. socket motherboards support DDR 1866, I am going to have to assume that you mean what motherboard will AUTO-detect the DDR 1866 memory as that speed? I don't know and such will take a lot of study. I expect this to vary also by whether the ram is on the motherboards makers 'vendor list' as having been at least minimally tested.
I would still feel that a specific motherboard, running memory specified by the manufacturer, can be manually adjusted to run at DDR 1866. In reading some of the posts for users specifically testing AMD APU setups, they have reached DDR 2000 and beyond when tweaking and testing their boards and ram.
Out of the multitude of motherboards, I would pick the one that most closely fits my specific needs and then google that motherboard model and add the DDR 1866 to the search and likely see what an actual user maybe experiencing overall. Now those types of user experiences, do bear a good bit of weight when I am seaching for my next piece of hardware.
