A7V8X which temp. sensor is which?
doer
EU, Finland
Hi,
I'm just wondering... which temp sensor is which on this Mobo. I can't overclock it before... (xp1800+ tbred) Bios 1010
MBM5 reports
Asus1 30*C
Asus2 40*C
Asus3
Asus4 23*C
Asus Probe2
Cpu 23*C
Mb (motherboard) 30*C
Sisoft Sandra 2003 standard
Cpu temp 40*C
Board temp 30*C
Power 12*C (I haven't connected it)
So, should I believe my cpu is running cooler than my Mb lol? Or is motherboard temp right 30*C which seems a bit high with my cooling?
Plz suggest where from to get the facts.
go to the mbm web site and dowload the newest version and the a7n8x update, that will give you a diode option im mbm5 and give you the correct temp :)
