Hello everyone
As you probably noticed I'm new here... Unfortunately, instead of bringing you a happy introduction, I've a sad story to tell.
Last Friday I installed an AMD Athlon XP 3200+ (Barton) on my Asus A7V8X-X motherboard. Ok... Via KT400 on these boards is not officialy supposed to run at 400Mhz, certainly not if you've bank 0 and 1 containing each 512MB DDR3200. (see manual).
So I installed it and it was detected as an Athlon XP 2500+ and for the rest, runs stable with Linux and Windows.
Next, I changed the bios settings to make it run at 2200Mhz. It was detected as Athlon XP 3200+. CPUID detected a 400mhz fsb
I was very pleased, exept that I got a memory read error trying to start Half-Life 2 or 3D Studio Max 6.
CPU speed fluctuated between 2200.0 and 2200.2Mhz.
CPU temperature reached 65° C (AMD Boxed cooler & heatsink)
Case temperature reached 38° C (Chieftec Full Tower, no case extra fans)
After reading a lot on the internet, I shouldn't run it at that speed after all and get the newest bios revision from asus: revision 1013.
I downloaded that file and copied it to a 1.41MB disk. Then I rebooted the system and entered the EZ-Flash utility. It recognized the image and asked me to confirm to proceed. Like I did last time, I flashed the bios and the boot block.
EZ-Flash than told me to press a key to reboot and that's when nightmare began.
The first line I could read on the screen was BIOS ROM Checksum Error and the system asking me for a disk with the bios image. Luckily for me, I made a backup of the bios before flashing.
Bad luck for me... the keyboard doesn't respond. I had no other choise than press reset of do a soft power off... I choosed for the reset button.
I think that's the choice that killed my bios.
Screen went black, no keyboard, no mouse, no A: drive being accessed... I don't even think it did POST at all.
Ok... keep calm... get the manual and start reading...
CMOS clear. I did it step by step. No change
Removing the battery and power cord again, and pressing that damn power button in the hope to drain all remaining charge... also no change at all.
Apart from trying a hotflash, which I'm not gonna do , I've no idea what else I could try. Replacing the AGP card by a PCI one doesn't work either. I didn't try to remove one bar of memory yet, but it doesn't look like it will sovle boot problem.
For first time ever, it looks like I'll have to get my pc to a technician. The guy in the store told me to bring the whole case. I don't like that. I've personal information under Linux which should be not accessible by them, but they might destroy the data by picking the wrong hard disks when trying to recover Windows XP for instance. Or when they send the whole thing to a Asus service center... I don't wanna think how they'll handle my baby.
Worst of all, I went to see my retailer about it forgot to ask what it's gonna cost me. Maybe I should give him a call first.
I feel really bad that I can't solve this myself.
Ok ... I could get a pair of PLCC pliers and order a new chip with the software preloaded on it. That's probably the cheapest solution. 6 € for the pliers, 25 € for a new chip with preloaded bios software of choice. I'd might try that one.
On the other hand, if it's the store solution and it's gonna cost me more than 50 €, I could just order a new motherboard, certainly after that Barton fsb lock story seems to be true (see below).
My idea was to buy a Gigabyte GA-7N400 Pro2
It looks like a good product. People seem to be happy with it and it has 2 bios chips... The board cost less than 100 €.
I'm starting to question Asus' reliabilty here... I downloaded that same bios chip twice at ftp://ftp.asus.com.tw/pub/ASUS/mb/socka/kt400/a7v8x-x/A7v8xx13.zip and had 2 different MD5 checksums for the same file saturday.
Today helpdesk.asus.com is down. Yesterday it was the download site which was down...
And my Asus gforce4 also returned once to their service center for a burned gpu as the fan (dirt-less) stopped working. I had to wait 3 weeks for getting a new one.
Can someone tell me what I should do to get that bios back to life or give me some advice on possible solutions ?
Thanks in advance
FSB Lock story...
It is said that the barton core cpu locks themselves to the fsb they're running on after 39 weeks of useage. I read that on several tech forums and still don't know if it's some kind of hoax or real stuff...
But if it's true and that the A7V8X-X runs at 166 - 200 or 333 Mhz, I'm better of with a new motherboard with 400Mhz fsb.
Thanks in advance
FSB Lock story...
