I apologize for the length of this posting, but the system details are essential to understand the problem. It is a new build system:
ABIT IC7 G motherboard with retail P4 3.0 Ghz Northwood CPU (SL6WU). Flashed to latest BIOS 28. 1 Gig of OCZ Platinum PC3200 Series II RAM -- (purchased as a matched pair). CPU voltage currently is set to 1.675v, DDR SDRAM is set to 2.8v and AGP is set to 1.65v in BIOS. Overclocked to 3.54 GHz -- FSB 236MHz. ThermalTake XP90 cooler with Artic Silver 5 thermal compound -- running at 44C idle. Running Windows XP Pro. ATI Radeon 9600XT graphics card. C drive is a Western Digital 200Gig drive alone on the primary IDE connector. The power supply is a new ThermalTake 480w PurePower. In a well cooled full tower case. Almost no software or hardware cards in the system yet. CPU/Mem set to 1:1. The PCI/AGP are locked at 33/66. Latency is is set in BIOS to 2.5, 3, 3, 7. The Northbridge strap is set to 800.
CPU-Z reports slightly different values. FSB measures at 236.2MHz so CPU is operating at between 3543.6 and 3543.9 (varies in that range). CPU voltage varies between extremes of 1.584 and 1.648. 1.600 and 1.632 are the most frequently reported values -- which are consistent with ABIT's undervolting of the CPU.
The problem that is driving me crazy is that the system freezes -- requiring a power down and reboot to regain control -- infrequently and randomly. No errors in overnight runs of OCZ Memtest, but system eventually freezes when running Prime95. Have run Prime 95 for as long as 24 hours with no errors but generally about every 8 hours or so the system freezes requiring power down to regain control. Does not show an error has occurred even though the system is frozen. I am an experienced overclocker and have spent several weeks varying voltages, latency setting etc. with no effect. The freezes are so intermittant that it is an all day job to check whether a change in a setting has made any difference or not. The temperature rises to around 50C when running Prime95. Given the ABIT bias to report CPU temperatures about 7C high, I interpret that to mean the CPU isn't going over 43 to 44C when running Prime95. So temperature is not the problem.
I am hoping that someone with experience on a similar system may have a suggestion. I have run out of things to try.
Thanks for your help.
PS
The system is a wonderful performer -- if only it didn't freeze. SiSoft Sandra reports 10,841MIPS and 4497/7811 MFLOPS in the arithmetic benchmark and RAM bandwidths of 5642 MB/sec Int and 5613 MB/s FP.
PS
