KenDingo said:I just made an acrylic case, and I got all of my supplies at Home Depot. They had everything I needed to make the case. I am at work right now so I do not have the links to the items I bought, but I will post them when I get home.
As for grounding, that is done through the power supply. That is the reason for 3 prongs on the PSU plug. The case has nothing to do with grounding.
KenDingo said:I was just speculating since I do not see any grounding straps to the case. Could you explain how the case is used for a ground? I am just trying to understand this a concept more.
Captain Slug said:Please don't use acrylic. It's not very sturdy, it's prone to cracking, and it's a reall booger to tool.
LEXAN/Polycarbonate is far more durable and easier to work with. Price is dependant upon your source. If you want to save 20%, check your local phone book for the nearest Plastics supplier or shop.
Otherwise you can order specific size sheets from McMaster.com (search for polycarbonate). Home Depot only sells 1/8" pieces.
P.S. You don't really need to ground the case. But I recommend using a premade motherboard tray cut or stolen from another case. It saves alot of build time and hassle. If you can't get one, atleast use stand-offs when mounting the motherboard to the case.
LEXAN/Polycarbonate is far more durable and easier to work with. Price is dependant upon your source...
Yes but it require higher temperatures to do so (275f-350f). The benefit of heat-warping Polycarbonate is the fact that it DOES NOT leech off toxic fumes (unlike Acrylic).loner said:Sorry for thread hijack, but is lexan shapable (heatable and bendable) like acrylic?
and Rhinex and GE (which makes Lexan but a number of government marked sheets don't have the brand LEXAN printed on them). I got some smoke-tinted GE sheets of 1/4" polycarbonate for next-to-nothing at a vehicle junk yard. The sheets were meant for replacing the windows on City Buses.Fushyuguru said:I get mine off ebay actually. Its cheaper than everywhere else (this stuff can get expensive). Just look for stock Lexan, Hyzod or Tuffak. Its all the same stuff, just different manufacturers.
Just to clarify this point so as to not misinform. A PSU is grounded by connecting to earth, hence when you plug it into a three prong socket the outlet is providing the ground. One of the reason a three prong outlet is so important to computers. The shell just serves as protection to you the end user so you don't get shocked. Another thing to consider is yes the multiple grounds in both the molex connecter and atx connector, those are indeed valid grounds which all tie back into the plug in the wall. Hope this helps you guys a bit as the metal shell is almost always commonly thought of as a grounding device. Now on a side note, the metal shell does serve as a EMI Shield to some extent.BlueWraith said:
Most powersupplies are grounded to their own shell, and then the shell is attached to the rest of the case with screws. As for how much use it has, I'm not fully sure. I'd use the grounds in the molex for anything that I needed to be grounded out such as a neon or fan.
