GraywolfPrepper
- Jul 3, 2013
Hi guys. I'm hoping you can help. I also hope I'm in an appropriate forum for the question.
I'm working on a system that involves an adapted bong cooler. It won't be cooling a computer system but I guess it could be adapted to do something like that. Shuffling around the web, you guys have the most useful info and experience on the topic so I'd like to throw a few questions out there and see what you think. It dives into swamp cooler theory a bit but I should be good with that end. What I'm trying to do is make a pseudo volenti cooler tube and double that with cooling the air, which is the primary goal.
I'm trying to adapt an existing single stage evaporative cooling system for remote cooling of tents and shelters in desert regions. Their idea works fairly well but I'd like to make some improvements.
Instead of just using a container with a single output that has wet pads on the input (the direct stage), I'd like to precool the air going into the system by using a radiator (probably an auto transmission cooler or similar) to improve efficiency.
Here's a sketch of what I'm looking at at the moment
Essentially, The cooling tower will hopefully provide two functions. One, it'll be an evaporative cooler that cools the air inside the center tube by evaporating the water in the aspen padding surrounding it.
The water that supplies the shower/drip system will be cooled by the tower as well and will be pumped up to a transmission cooler at the dry air intake. The exit of that transmission cooler will supply the shower/drip system. The feed line up to the radiator will sit inside the tube to minimize heat gain.
I currently have a 3" inline 240 c.f.m. fan I'm gonna try, which will pull air out of the system (from inside the center tube, which will most likely be made of fencewire and aspen padding).
Depending on the heat gain of the air exhausted from the shelter (probably a lot from a tent), I may then feed back that air into the water reservoir on one side to exit out the other. That air is isolated from the cooling tower air by dropping the cooling tower into the reservoir and drilling vent holes under the water level for the return.
I have a few problems right now with the idea but I don't have all the parts yet to see if I'm right or how to correct them. I'm hoping to hone in on the design first and then adjust later (measure twice, cut once I guess).
1 - I don't know if I'm loopy with this idea
2 - I'm not sure about how much volume of air I'll need in the larger tube to ensure evaporation. Basically, can I pack it with loose aspen padding or does it need a lot of airflow.
3 - I'm thinking of starting with a 6' tower (arbitrarily) but I don't know what kind of pump I'll need to pull the volume of water that high for enough flow to keep the pad wet for maximum efficiency
I realize the water from the radiator will heat up but that should have a negligible effect on the energy pulled from the water as it evaporates down the tube. I'd like the cooled water to precool the air into the system (thereby increasing the efficiency of the evaporative process) without adding humidity to the system until it gets pulled into the center tube.
Anyone see issues right off the bat before I start fabricating?
