My blowhole works best on those hot summer days where the heat just keeps buildin and building on it's self. I have 3 intake fans at various posisitions and 3 exaust fans. try the duct approach if your blowhole diden't make much diff.
[duct description]
my side intake fan's airflow is splitup and directed in 3 different directions(onto the northbridge, combined with rear duct for cpu, blown onto the ram)
the front intake fan is blown accrossed my hd and then blows acrossed the ram kindof.
the rear intake fan is directed straight into my tornado which is also combined from a duct from the side intake.
(used airflow)
the air coming out of the upper and lower left of the cpu hsf is redirected by a duct into the 92 mm psu exaust fan.
the air coming out of the upper right of the cpu hsf is ducted straight to the blowhole.
the air coming out the lower right of the cpu is combined with the air from the side intake fan and blown acrossed the northbridge which then eventually finds it's way to the 80mm exaust fan on the psu.
there is no ducting on my vid card since i don't overclock it.
[/duct description]
so you might say that i have slightly positive airflow.
the extera air being blown to and sucked from my tornado makes it spin 500rpm faster than without the duct work.
which also makes it about 10dB louder
ducting the air makes sure that the air won't sit around in your case and recycle its'self. (it also helps to have a psu with a few extera fans than the normal cheapo ones
