- Apr 14, 2011
Don't really have a specific question at this point, but I wanted to keep everyone posted on my progress so that I could get comments as I progress with my first build. I'll post pictures later tonight, and keep you updated as I add the last few mods. I am totally open to suggestions/comments/criticisms, particularly since this is my first custom build and I am just learning about overclocking.
Here's what I've got so far (see my sig for the details):
I've installed everything and have had my OS up and running for about 2 weeks now - the only cooling mod I've made thus far is adding another antec 120mm blue led fan to the side case port, which helps quite a bit since the ambient temperature in the room is pretty chilly (around 62f generally). I feel like I've done a decent job of cable management (again, I'll post pictures later today or tomorrow), I've tried to keep everything out of the way of airflow and I've sleeved wherever I can for aesthetics. I have 4 extensions on the way as well so that I can get the CPU power routed behind the motherboard tray instead of right in front of the case window, and because the 6+2pin PCIe connectors from my PSU are ugly and also right in front of the case window. That should help a lot with the look.
Here's the primary reason for the post: my CPU cannot handle ANY oc'ing with the stock cooler; when I run prime95 at stock speed, it shoots up immediately to about 62c on the cores (hwmonitor and the LED on the board both read the same) which as I understand it is the absolute top end for the Phenom II x6's. I tried to OC just 100mhz using the multiplier and can't even boot. My Ram is "OC'd" to 1600mhz, although that's what it's rated at. I looked at the timings and I think my board detected correctly.
That said, after some research I've ordered the Antec Kuhler 620 -- couple of reasons: 1) I'm trying to make the build look nice, thus all of the massive fan/heatsink combos really don't appeal to me. 2) I'm also not sure they'd fit in my case (the heatsink over the NB on this board is BIG, and there's not a lot of space between that and the rear of the case). And to be perfectly honest the brown fans on the Noctua turn me off a bit.
Here's the plan, and please feel free to comment: because the exhaust fan is already in place on the rear of the case, I'm planning on mounting the radiator directly to that one, and using the fan included with the Kuhler on the other side as an "intake" into the radiator, so I'll have a pusher and a puller. I may rearrange based on LED's and what looks nicer in the case, but I think with my hardware that's going to be my best option. Any thoughts on that?
I'll keep everyone updated as I install, and I'll show the results as I attempt to OC -- I'd love to get to at least 4ghz.
