- Mar 15, 2005
- Buffalo, NY
Anyone had this problem? I cannot install adobe acrobat reader 7 on to my machine. It always fails by giving me the good old "this program has encountered an error and needs to be closed" error during the installation. I've tried every version of install file that I can find for reader 7 but they all give that same error. I mean I always knew I hated Acrobat for bieng a bloated POS program but now I hate it even more. Its not like I NEED it right now, but since so many freaking corporations decide to make bloated files using it I'm gonna run into a situation soon that requires it.
FWIW I'm running fully updated XPSP2 (yes, its actually a legit copy ). I've also been doing this at stock settings just to see if maybe my OC was giving a little stability error somewhere despite the fact that its perfectly stable in all other apps, and it still errors OCed or not.
If any of you can suggest a good way to get reader 7 installed I'd appreciate it, otherwise I'm just gonna find some old driver disk with version 5 or 6 on it and try that. Would like 7 though just so I dont have it constantly bitching to me about upgrading
