In detail, when I run Prime95 [or game], ABIT AGURU reports that the 5VSB jumps to 5.9V (Why?) and then the 12V dips to 10.8V (at which point, the computer will simply reset itself.) I tried a second 350W PS just for the hell of it, and the mobo wont even make it to Windows, just shut down. I also notice the DDRVdd levels fluctuate sometimes, then Prime will error out. This doesn't happen very often though.
I currently own a 400W RAIDMAX PM-s400, about 2 years old, that supplies the following current: +3.3V@28A, +5V@30A, +12V@15A, [email protected], [email protected] and +5VSB@ 2A.
I did notice, on one occasion, a smell coming from the PSU, but its ok now.
I have the following components installed:
ABIT AI7 w/Prescott 2.4GHz @ 3.6GHz [18x200] 1.535V
1GB DDR @ 160MHz [5:4 divider] 2-2-2-5 3.1V
eVGA 6800 Non-GT/Ultra
15KRPM IBM Ultrastar
10KRPM IBM Ultrastar
2 x 7200RPM Maxtor 160GB 8MB
2 x DVDR/DVD
ADAPTEC SCSI 29160 x 1
SoundBlaster Audigy
3 x 80mm LED fans
2 x 80mm Case fans
1 x 92mm Vantec Tornado
Now this is what I'd like to know:
1) What is the 5VSB and why is it going to such extreme voltage levels? I know its standby Voltage, but shouldn't it drop instead of raising?
2) As I do realize I need a power supply, what Amperage on what specific rails should I be most concerned with?
3) What specific components in my system is causing the most drain on the 12V rail, if at all possible for someone to determine?
4) Am I asking too many questions?
Thanks for the help~!
2 x DVDR/DVD
SoundBlaster Audigy
3 x 80mm LED fans
2 x 80mm Case fans
