- Sep 27, 2009
- MS Gulf Coast
My chassis fans are set to a standard profile in BIOS which provides the best cooling, but can be quite loud at times. If I switch to a silent profile I've noticed the CPU socket and die temps remain low while the chipset will run between 38-40°C when the system is idle.
I was previously using Asus AI Suite, but that is a junk program and speedfan isn't compatible with my system.
I need a good fan speed control application which will allow me to run a silent profile while idle or doing menial tasks and then switch to a performance profile while gaming. Any ideas?
