Hi, I had just ordered the Nepton 280L (the new version isn't out yet), but have decided to send it back and go custom. I'm going to be ordering the XSPC Raystorm, either the 750 or D5 AX240 (open to other rads if they fit). I know the D5 is a much better pump and for now I'm just going to be cooling the CPU, but I might be cooling my 690 also. So would you guys say spend the extra cash and get the D5 for future expansion?
My current rig in progress:
Case: CM Stryker
Mobo: Asus R4BE
CPU: i7-4960x
Ram: G.Skill 2133 16G
GPU: NVidia GTX 690
PSU: Antec HCP-1300
Will be adding a Samsung Pro SSD and a HDD.
Thanks!
Case: CM Stryker
Mobo: Asus R4BE
CPU: i7-4960x
GPU: NVidia GTX 690
PSU: Antec HCP-1300
Thanks!
