LiquidBoyyy
- Oct 7, 2017
Hey guys,
I'm an old member of the overclocking and gaming community, but somehow until today all of my gaming computers were air cooled.
In the last few weeks i started assembling my new computer, and i think i want it to be water cooled this time.
The hardware is:
CPU - Intel i7 7820x
Mobo - Gigabyte AORUS gaming 7 x299
GPU - NVIDIA GTX 1060
Ram - G.Skill Ripjaws DDR4 3000Mhz
SSD - Intel SSD6 M2 512GB
HDD - Western Digital 2TB SATA
PSU - Corsair TX650M
My case is a custom build (by me), since it has to fit in a single cell of an IKEA KALLAX, which my desk is build of (Similar to this)
My current case is made from IKEA box which fits this KALLAX cell, the the parts were built inside this box. i'll never do it again, it was a bad mistake using an IKEA plastic box..
Anyway, my new case will be made from Aluminum Linear Rail Profiles (Similar to this)
I've read online reviews and blog posts, and among many opinions, I want to consult you guys about the final part list i've made.
Pump+Reservoir
Since the case isn't going to be very large, I went with this combo to save space
http://www.performance-pcs.com/new-...25-bay-res-pump-reservoir-combo-v4-black.html
CPU Block
This one isn't LGA2066 like my cpu, but i've read that the LGA2011 socket has the same screw distance.
it was also a good value for money, if you think you have another block with a better VFM feel free to share with me
http://www.performance-pcs.com/magicool-anycool-copper-cpu-block.html
Fittings,
I went with barb fitting and mot compression, since i'm going to be using soft tubing and i've read onlune that barb fitting are less pretty, but leaks less..
https://www.aliexpress.com/item/XSPC-G1-4-Thread-1-2-Barb-4-pack-Black-Chrome/32794127654.html
Clamps for the fittings
https://www.aliexpress.com/item/3-8-Silver-Thin-Pipe-Clamp/32234872161.html
Radiators:
2 of these 240mm will give me plenty of upgrade ability in the future.
https://www.aliexpress.com/item/Mod...anger-Water-Cooling-12-Tubes/32818413688.html
Fans,
4 of those of course
https://www.aliexpress.com/item/Barrow-BF02-PR-RGB-12cm-Fan-for-Radiator/32825333079.html
Fan controlling hub,
https://www.aliexpress.com/item/SAT...nsion-Adapter-for-PC-Chassis/32826940384.html
This is the list guys, please feel free to comment about these if you think i need to change anything.
Thanks!
The hardware is:
Pump+Reservoir
CPU Block
Fittings,
Radiators:
Fans,
Thanks!
