Current air-cooled box is finally on its last gasps, so now I have an excuse to splurge on a new system. Going the WC route mainly for the reduced noise (my current box sounds like a hairdryer) and also the improved cooling. I have put together my own PCs in the past but am by no means a DIYer, prefer having everything laid out already and just assembling than drilling my own holes, etc.. Also relatively new to overclocking. Have a budget of around 3-4k for this build, and here's what I have picked out so far:
System:
CPU - Intel i7 920 (2.66)
Motherboard - Asus P6T v2 Deluxe
Memory - Corsair Dominator GT 6GB DDR3 1600
PSU - Corsair 850HX
Video - BFG GTX 295 H2O
Case - Danger Den Water Box
Cooling:
CPU Block - Swiftech Apogee GTX SE
GPU Block - Danger Den (pre-built into video card)
Pump - Swiftech MCP-655
Pump Top - Koolance PVP-450
Radiator - TFC XChanger 240
Tubing - Tygon 1/2" ID 3/4" OD
Here are my questions:
1. Is a single loop enough for this system? If so, how fast would I be able to OC up to and is my PSU strong enough to handle it? Think my biggest constraint is the space available inside the case. I'm not dead set on the case yet so can switch over to a tower supporting a triple radiator if necessary.
2. Here's the loop setup I was planning - is everything in the right order?
Pump --> T-Line --> Radiator --> CPU --> GPU
For a single loop I read it might be better to add a second radiator between the CPU and GPU, but don't think it'd fit in the case. But again, not dead set on the case yet.
3. Any recommendations on what fans to use with the Feser 240? Read reviews that it works best with low-medium speed fans, so hoping it's quieter. Then read somewhere else that performance drops off the lower the fan speed is, so a bit confused about that point.
4. When I'm shopping for fittings, if all the parts I'm getting fit G 1/4, do I need to worry about getting any additional adapters? Currently just buying G 1/4 compression fittings, no hose clamps, barbs, or nozzles. Worried I might be missing something and don't want to be placing multiple orders.
That's all I can think of right now. Thanks for the help all !
Much appreciated.
System:
PSU - Corsair 850HX
Cooling:
Much appreciated.
