Hello Everyone,
I've had the below build for probably 4 years now and plan to upgrade in a year or so, but we just bought a house, so I don't want to blow that much money on a full upgrade just yet. However, I would like to make some adjustments to address the heat that the system produces while trying to keep noise down if possible. I don't really do any overclocking and just use the system to play a few games and share music and video with remote XBMC systems.
CPU: i7 CPU 920 @ 2.67GHz
MOBO: EVGA X58 SLI (E758) LGA 1366
RAM: 16GB (4x Corsair XMS3 4 GB DDR3-1333 DDR3 SDRAM)
GPU1-2 (SLI): 2x EVGA GeForce GTX 460 Superclocked 768 MB
HDD1-2 (No Raid): Western Digital 320GB 7200 RPM
HDD3-6 (Raid 5): Seagate Barracuda 1.5TB 7200 RPM
CASE: A really old Alienware that I've upgraded all original hardware from since I bought the system some 10+ years ago. I'm talking pre-Dell timeframe when Doom just came back.
My first thought was to look into a water cooling solution, which does have the "cool" factor, but don't want to spend more than needed to solve the problem. Thinking about it more, I assume that maybe a better case with properly placed fans and an upgraded CPU fan would allow better airflow overall and maybe reduce the heat. What do you guys think about the below options? The VGA Cooler is a maybe since I bought one for an older Radeon card and it made a noticeable difference. I'm not locked to any of these, so please make additional suggestions if you have any.
==== CASE
$149 - COOLER MASTER CM Storm Series Trooper (SGC-5000-KKN1)
$145 - AZZA Hurrican 2000 CSAZ-2000
$120 - Rosewill THOR V2
==== CPU FAN
$78 - Noctua NH-D14 (20dB)
$24 - COOLER MASTER Hyper 212 Plus (32 dB)
$60 - ZALMAN CNPS9500A-LED (28 dB) with ZALMAN ZM-CS4A mount kit
==== VGA Cooler
$75 - ARCTIC Accelero Xtreme III VGA Cooler
I think I'm leaning towards the Cooler Master case with the Noctua CPU fan and maybe the VGA Cooler later in time if it's needed. I'm really curious what you guys think though. Thank you for your time and assistance!
==== CASE
==== CPU FAN
==== VGA Cooler
