Hello,
I've been running the loop bellow for 3 years and now that I'll change the video card and its block I realized that there are room to optimize it. You probably agree.
Equipment:
- 1/2 tubing
- EK blocks
- Swiftech Radiators
- Swiftech MPC655 pump
- Reservoir 150ml
- Chieftec BA01-BBB full tower case
Today my loop look like this:
Reservoir > Pump > Radiator 1 120x240 > VGA > Radiator 2 120x120 > Radiator 3 120x120 > CPU
Problems:
- Too much tubing
- Air accumulating at the Radiators 1 and 2 outlets due to the fact the inlet is at the top
- Radiator 3 with in/outlets at the bottom, probably accumulating air inside at the top
Now I want to rearrange the itens like te diagram below:
Reservoir > Pump > Radiator 1 120x240 > Radiator 2 120x120 > CPU > Radiator 3 120x120 > VGA
Notice that I flipped the R1 and R3 by 180 degree and changed the outlets of R1 and R2 to the top instead of the bottom
Do you think that this is the best arrangement or is there something else I'm missing?
Equipment:
- 1/2 tubing
- EK blocks
- Reservoir 150ml
Problems:
- Too much tubing
