Hey all!
Been building systems for a while now and it would be awesome to build my first custom water cooling build.
I'm running the following hardware:
And I made up this list to cool this baby:
I would add Corsair 120SP static pressure fans to the radiator.
Would these parts be compatible? And suffice for my system? Was doubting about the radiator size but since they recommend 120mm per component + headroom for OC.
Is the pump overkill for this cooling setup? Or is more flow always better.
As an extra, how much tubing do I need for such a large case, and how much coolant? (Appr.)
- i7 6700k
- Asus Z170 Pro Gaming
- Asus 980 Ti Strix OC
- Corsair Vengeance 16Gb RAM
- Samsung 970 Pro Nvme
- Corsair AX860
- Corsair 750 Obsidian
- EK-VGA Supremacy - Acetal (GPU BLOCK)
- EK-Supremacy EVO - Acetal (CPU BLOCK)
- EK-XRES 140 Revo D5 RGB PWM (Reservoir Inc. Pump)
- EK-CoolStream PE 360 (Radiator)
- EK-Tube ZMT Matte Black 15,9/9,5mm (Tubing)
- EK-ACF Fitting 10/16mm - Red (Fitting)
- EK-CryoFuel Clear Premix (Coolants)
