- Sep 10, 2002
- FL, USA
Right now i have a xp 2100 and i wanted to know if its worth upgrading to a 2500 barton
Bman1238 said:Personally, I would go with the Barton 2500+. With phase change cooling, or even a good air setup, chances are that you could get the 2500+ running at the speeds of the 3000+ or possibly higher. You could also get the 2100+ running at the same speed as the Barton, but with the extra cache, the Barton would have the higher performance.
