- Jul 9, 2013
- Sadly Iran :(
I'm building a PC for a friend.
I personally without the slightest thinking smash my GPU and everything inside the motherboard while touching the PCB and although I've only build a single pc ( had to replace HDD and GPU once, and other things) I never had a problem.
But this is my friend's and the PC is so expensive. I do have a antistatic wrist band
But... I have no ground... Just a 2 pin 220v outlet. So if I just connect the wrist to my unplugged case. Will it be safe? His father is a scary guy xD but not as scary as 1000$
I do have a power hub which has just a few capacitors and an MCU inside (So I don't think it's REALLY safe) but a power spike could even kill it. Am I overthinking?? Or should I find a way to ground myself properly
