Hi all
Having an issue with msi afterburner on my benching setup. There is no networking installed on that build.
Whenever I try to start afterburner it hangs for a couple seconds then throws an "unable to connect to server" error and closes itself down. Anyone experienced this issue?
Wondering if changing the config file will help. There's this entry:
UpdateCheckingPeriod = 3
Will changing the value to 0 fix this issue? I'm not home or I'd try right now.
If that fails (and if nobody knows a 'fix') what other overclocking app should I use? Not sure if it makes a difference but am running only green team cards atm.
tia!!!!
tia!!!!
