Specifically, on my AMD chrosshair V it was causing my system to not shut down using windows. I needed to hold down the power button to get the Pc to shut off. I've had other issues with my Intel setups. That all said if you're not using it just uninstall it or just ignore the pop up. There isn't anything wrong with what it's showing if you're worried.
