- Apr 8, 2012
- Hagaman, N. Y.
I use a 200 watt heatload because it's not hard to get there with a quad (or more) core processor and have it stable at that speed for years on end. Besides testing heatsinks, I also run DC projects with my systems and that means 100% load 24/7/365. And there are quite a few people on these forums that do the same thing and with proper cooling and keeping voltages below Intel and AMD's max vcore guidelines you won't hurt anything. My younger brother still has some old Conore dual cores and a Q6600 quad I ran for years overclocked in the 3.4-3.6 range and they are still going strong. If you keep vcore reasonable and keep the proc cool, you can push your proc for a long, long time without failure. And since I have had such good success with this formula, I look for heatsinks that able to handle that kind of running. As for my Bloomfield at 4.0, that processor hardly needs any vcore adjustment to run there. I actually run it at a higher than needed vcore at 1.305 volts to get some extra heat for testing. If it weren't a test system, it would also be running BOINC 24/7/365 at that overclock, as that proc easily handles the speed without passing Intel's max vcore guidelines.
I owe you an apology. For years I used the same site for my HSF reviews, but times have changed and so must I.
